was going great until the piece around the shaft going thru the bell housing proved too large is this the infafmous bearing held to case by 4 nuts if I take it off is the case drilled to accept a smaller one or do I need another bell housing
Measure the bell again. It should be either a 4.354" or 4.805"
If it's a 4.354" you can machine the bellhousing out to 4.805" and run this bearing retainer https://www.summitracing.com/parts/dcc-4529696. If it's 4.805" you can just run that bearing retainer. Either that or you need to find a new bellhousing.
The 4.354" retainer bellhousings can't be opened up all the way out to 5.125", 4.805" is as far as they'll go. Likewise, you can't put a bearing retainer with an outer diameter of 4.354" on an OD or later 308 input bearing transmission because the bolt circle for the bearing retainer is 4.16" on those, the transmissions that original had 4.354" diameter bearing retainers had a 307 bearing and a 3.7" bolt pattern. If you have a 5.125" bearing retainer on there now you have the 4.16" bolt circle.
Blu I didn't think the 4.805 retainer worked on the O/D trans. Am I mistaken?
There are two 4.805" retainers. One has the 3.7" bolt pattern and one has the 4.16" bolt pattern. The one with 4.16" pattern bolts right up to the OD transmissions, that's how you can put one behind a big block because they never made a BB bellhousing with 5.125" retainer opening. The later 833's had 308 bearings just like the OD's.
