jbc426
Jbc426
Which torque converter did you go with, 9.5 or 10.5? Is it a single or duel disk lock up?
It's the full sized converter with a 3 carbon fiber disc lock-up clutch, anti ballooning plate and billet flywheel.
Jbc426
For those of you that are on the fence to install a 408, I'm assuring you it's worth it. The more I drive it, the better it runs. Smile will not leave my face while behind the wheel. I'll get some pics posted soon. 10-1 compression works on the lousy 91 pump gas with ethanol. Very streetable build and WOW does it sound good without the weight of a big block. The Mopar M-1 manifold works much better at lower rpm's than I expected as well.
What are you running for gears ??
I personally think if you want bigger than 360 go big block but I'll probably add to the 408 ranks one day or at least 3.79.
Simply cause as I add power to my 380hp create engine I will have too much invested into the small block platform.
