[SOLD] 410 ci stroker small block
RAMCTD2003
340dart
Grand Junction, Colorado
I have lost interest in this project so here it goes.
Mopar smallblock stroker (410 c.i.) 1977 360 block bored .040,
Edelbrock60779 aluminum heads, comp cams adjustable roller
rockers,comp cams hydraulic flat tappet cam .545/.545 lift 285/297 duration,comp camsdouble roller timing chain, probe 10.25-1 forged pistons,h-beam rods,cast crankshaft, internally balanced, summit racing air gapintakemanifold + edelbrock rpm airgap, edelbrock thunder series 800 cfm carb, dual feed fuel line, edelbrock fuel pump,braided fuel line from pump to carb, MSD e-curve distributor,performance products balancer, march 6 rib water pump and crankpulley, msd 8.5mm wires, milodon 7 qt oil pan. Mopar performance polishedcast aluminum valve covers. Includesbrand new Schumacher motor mounts. Will post pics tonight when i get home.
Has neverbeen started.
Over $9500invested. Need the money to buy a house.
$5800. Located in Grand Junction, Colorado.
Would you consider shipping it? I'd like to see pics then we can talk. I'm interested.
Rick
Here are the photos that I promised.
