hilbillyconques
- Joined
- Dec 3, 2007
- Messages
- 46
- Reaction score
- 0
i finally am getting some work done on the 416 , it will still be a couple of months before finished , but i was wondering what you guys thought it might run, horsepower it will make?
it is a 30 over 340 block with 4 inch k-1 forged crank and rods , diamond dished pistons the compression came out at 10.1. the camshaft is a solid flat tappet with 252 at 50 intake 260 exhaust with a gross valve lift of 614 intake 597 on the exhaust . the heads are 360-1s with shady dells stage one port and polish, indy intake and a 4781 850 holley dp .it will use 1 7/8 tti headers with 3 inch exhaust to the rearend and it has a 3800 or so dynamic converter 727 with brake , and will run a 3.91 gear for now , the slicks are 26x8.
it will be going in a 67 dart that is about 3400 pounds with driver, the plan was to make a decent pump gas street car that later could add compression and a roller if needed.
if i forgot anything just ask and i will try to post some pics so you can see how it is going.
this is how it looks now
cam card
flow chart for the heads
intake shot
chamber with o-ring
t and d rocker 1.7 intake 1.6 exhaust
i really dont have any good pics of the car but i will post the ones i have now
thanks in advance for the help guys.
cam card
intake shot
chamber with o-ring
