SpeedyDart68
Just say no to trailer queens!
422" X-BLOCK W2 ENGINE:
X BLOCK 4.100" BORE, 2 BOLT MAIN, O RINGED WITH COPPER GASKETS, 2 SLEEVES, SHORT FILL
MP 4.00" STROKE, FORGED CRANKSHAFT # P5007252
EAGLE 6.123" H-BEAM RODS
ROSS PISTONS 12:1 C/R
W2 OPEN CHAMBER RACE HEADS, STAGE 3 PORTED BY HENSLEY PERFORMANCE
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]HARLAND SHARP 1.6 RATIO ROLLER ROCKERS[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]CRANE CAMS ROLLER LIFTERS[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]CAM MOTION SOLID ROLLER .688 INT/ .670 EX LIFT W/ 1.6 RATIO 270* INT/ 276* EX @ .050 CAMSHAFT[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]CLOYES TIMING SET W/ TENSIONER[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]ATI BALANCER[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]B & M FLEXPLATE[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]INDY 360-2 INTAKE PORT MATCHED[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]HOLLEY #80514 1000 CFM 4150 CARB[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]K & N XSTREAM 14" AIR FILTER[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]CHARLES FAB ALUMINUM OIL PAN[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]MP POLISHEDE ALUMINUM VALVE COVERS[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]MSD CRANK TRIGGER[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]MSD 8534 BILLET DISTRIBUTOR
MSD SUPER CONDUCTOR WIRES[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]MOROSO ELECTRIC WATER PUMP[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]MOROSO ALTERNATOR MOUNT[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]EAST COAST 50 AMP MINI ALTERNATOR
25 1/8 MILE PASSES SINCE FRESHENED BY RYAN JOHNSON @ SHADY DELL SPEED SHOP[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]THIS ENGINE HAS BEEN A BEST OF 6.27 @109 / 9.90 @133 IN A 3250 POUND A-BODY WITH TOO MUCH GEAR[/FONT]
[FONT=HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif]NO COOLING ISSUES, VERY RELIABLE COMBO THAT MAKES GOOD POWER.[/FONT]
**** ONCE OWNED BY MIKE GRAY IN VIRGINIA ****
ENGINE IS NOW LOCATED IN TULSA, OKLAHOMA. MUST SELL!!!!!! :burnout:
