flathead31coupe
does the vapor return line have to be steel...
Or you call a supplier of quality pre-bent lines and get the exact piece for your car at a very reasonable price , then modify the ends to suit the different path of the return line . As Rusty said stay away from substituting rubber , in the late seventies early eighties Furd ran plastic lines on the Capri Coupes , a gravel road with a swale left my buddy walking home and a large puddle of raw fuel under his Crapi . Some lessons have to be learned hard by some people !
thanks for the reply, 850 dp holley.. eddy intake with the heat crossover not blocked under the carb..recently added a return to the tank with the wix filter,,, if my return is working will I have pressuer on the fuel gauge at the carb after I shut it off...and when it does die, there is no pressure on the gauge...I can hold it to the floor it will start and run fine
what do you mean flow through the carb ? do you have a pic or drawingHow is your fuel return plumbed? Does the fuel flow through the carb bowls and then back to the tank or do you just have the return in parallel with the carb? If it's the second choice the fuel is just sitting in your carb until it gets used by the engine thus giving it a chance to heat up. Also definitely look into a carb spacer made out of either wood fiber or phenolic (plastic) at least 1/2" thick, and finally unless you drive your 440 in the winter go ahead and block off that exhaust crossover.
I swear every year pump gas gets sh!ttier, in a few years it'll boil off at room temp and 91 will ping like 75-octane
cool thanksThe way the mechanical pump works is to receive a swat from the eccentric bolted on to the front of the cam,which happens every second revolution. Then the pump tries to move a little fuel up the line. At idle, only a tiny bit will enter the float bowl. The rest will head back to the tank via the return line. If the WIX filter has a checkvalve in it or a fixed orifice, then there will be a brief pressure spike until the pressure equalizes as the fuel passes thru it. The fluctuating gauge is just reflecting what is happening.
good point. no spring no pumpThe Wix filters have no check, they are a simple orifice. It might be worth mentioning that mech pumps do NOT pump from cam action, exactly. The cam "cocks" them, it is actually the spring in the pump which moves fuel on the return stroke, and this is why they regulate pressure. The pressure is limited by the strength of that spring. When you are "light" using fuel, the pump arm can "float" on the cam, barely touching it if no fuel is needed, and the needles are closed. This is also why you can run a rear electric in series with the front pump and it won't increase pressure. The pressure with two pumps will be whatever the highest pressure one puts out.
First car I ever had or saw with a return system was my 70 440-6. AND IT WORKED. I know because for some reason I removed it......................................................I remember........
Had an electronic pump I can NOT remember the name of, and it never shut off. Turns out that was design. I thought the return was the problem and pulled it off LOL. First few hot days (I was stationed in San Diego at NAS Miramar then) it would lock
Here we go but I don't remember this brand and mine was not blue........might have been sold under different name, but this is "the" pump..
