71Duster440
New Member
Hi, my name is Dave, and I am new to this forum.
Here is a little background of my car and build I decided to take on...
I have a 1971 Duster, original Slant 6/904 trans, sbp car.
I decided I had to do a big block in the car, so I went and got a worn out 440 block & 727 trans from a motorhome.
Had the engine completely rebuilt, bored .60 over, forged internal, "X" code block.
I am interested in using a Demon 750 carb, but was told I may have an issue using the transmission cables for the upshift/kickdown cables.
When I bought the transmission, the guy gave me a brand new 2800 stall converter, as well as a complete rebuilt kit to go with it, but I do not have any of the original shift linkage or cables.
My car will be a floorshift car, and I am going to use a Cheetah SCS shifter, which can be found here:
http://turboaction.com/frame.html
My question is, will this set-up? and what other components will I need to complete this motor/trans set-up?
I still need to upgrade the rear end and drive-line, and several other components, but this is the battle I'm currently trying to figure out.
I work in Bremerton,WA with the President of the All Around Mopars/Mopar Magic car club, and the members of the club told me turn to you guys for an answer. Thank you for your time!
