jeeper
Hello All,
I have been deciding between a BB and a SB Duster.
Here is what I have for the BB:
Mid 70's 440
452 Heads with a valve job
It will get a rering kit and be run as is. Cylinders look good but I have not mic'd them yet.
Intended build:
Bigger Summit cam and appropriate springs
Template port the heads
.020 gaskets
Stock intake for now
Hooker 1 7/8" headers-fenderwwells
I realize that the compression will be lower than desired but it will have to work for this year.
Fairly stripped 74 Duster with 4.10's.
Any ideas on Horsepower/Et's with this combo? I may be able to spring for a cheap convertor.
Thanks, ROB
Mid 70's 440
Intended build:
.020 gaskets
Thanks, ROB
