Vamisk
Put new rings and bearings in it. Has an oil pan for an A-body with the cut. This comes with a boat anchor intake and B body headers. I have new exhaust manifold studs not installed and a water pump impeller. The thermoquad in the picture has a cracked float body housing but if you want it you can have it. Unfortunately painted it Ford blue just to keep the rust off.
Installed a Sum-6400 cam: Duration 288/298, Lift .444/.466,
It needs a single ARP bolt either for a main or a rod, one got stripped out before i was able to put it in so I used a factory bolt to get it together.
Local pickup in 19363, I can drive it around within reason but i cannot ship this.
I'll be adding more pictures tonight.
