Shadow9198
Active Member
I don't know if i'm allowed to sell things here but if not let me know. i have a 5.7 hemi hotrod wiring harness that i bought from hotwire auto. it worked great when i used it but now i am going a different path and wont be needing it. the harness is meant to control the engine and trans mission and only plugs into the stock ECU. this harness will also work on the 6.1 according to hotwire but will not work on the 6.4 (im assuming different plug styles). if you run a manual trans you would have to force a ground on the transmission relay and it would work fine. the only things i changed on this harness were the starter solenoid plug (i wonder if mine was not stock or something) some wire lengths for the ones you have to wire yourself (ignition, starter, etc...) and i replaced the oil pressure sender plug as the red safety clip broke off. everything still has labels and i still have the instruction book lying around to send with it. im asking 1400$ CAN for it as i paid around 2000$ CAN to get it to my doorstep.
