BWDart
My new dizzy came with an orange box which has 4 prong orig had 5 is that a problem?
Thanks
Thanks
ThanksNo problem, it will work, no other changes needed.
Alan
The factory modules needed a lower voltage (along with the 12v) and Chrysler did it with the other side of the dual ballast resistor to the fifth pin.So I always wondered, what was that extra wire for?
I have a 4 pin ballast so I can just leave it as is?That diagram is AFU. It shows the coil bypass going to the yellow start NOT CORRECT!!!! The coil wiring is UNCHANGED from the old breaker points system.
5 wire vs 4:; Even though a box has 5 pins that does not make it a 5 pin box. You must ohm out the pins to see if the "5th" pin is open to find out. Changes of actually buying a new 5 pin are fairly small, unless NOS
With a 4 pin box you can use either a 2 or 4 pin ballast. "The other half" of the ballast does nothing.
Ya I wondered bout that thanks for explainin itThe factory modules needed a lower voltage (along with the 12v) and Chrysler did it with the other side of the dual ballast resistor to the fifth pin.
The aftermarket modules did it internally with the 12v that was already there.
Alan
What do you mean "leave it as is?"I have a 4 pin ballast so I can just leave it as is?
Thanks for your help
The ballastWhat do you mean "leave it as is?"
Ok thanks AlanYes, all assuming you have OEM wiring, the 4-pin module just plugs in and works.
The 2nd half the ballast just does nothing.
Alan
The ballast
AFU? Whats wrong with that...START gets direct 12v to coil - bypassing the ballast resistor (same side as coil+) then in RUN, the coil gets ballast conditioned + voltage through ballast...is that wrong?
Mine is electronic from factory it was a better deal to buy the conversion kit than the new dizzy seperateYou could or replace it with a 2 pin ballast. As I said earlier the ballast wiring is not modified from breaker points with a 4 pin box. ON a side note, if it ever quits you, and you have a breaker points dist. you can just unplug the module, dump the points distro in there, and hook up the neg. coil terminal to the dist. wire. Off you go
Just use the distributor and module and don't worry about the harness or ballast.Mine is electronic from factory it was a better deal to buy the conversion kit than the new dizzy seperate
Ya wish I had a points dizzy I'd keep it in the trunkYou could or replace it with a 2 pin ballast. As I said earlier the ballast wiring is not modified from breaker points with a 4 pin box. ON a side note, if it ever quits you, and you have a breaker points dist. you can just unplug the module, dump the points distro in there, and hook up the neg. coil terminal to the dist. wire. Off you go
