Since i don't have either trans, that would give me options to put an OD trans together.
Did a 518 behind a 500''RB.Had to cut off the small block bell and install a bolt on JW bell. Uses the front pump bolt holes.This was in a street car and was fine. Tough like a 727. That was back in 2003.I have kicked around the idea of putting one in my old 1 ton Dodge.
NO, even with swapped sides > master cylinder moved, notch clearance on passenger side, pass. shock upper mount moveddo the maxi exhaust manifolds fit without cutting?
