[FOR SALE] '63-'66 front door hinges w/ hardware
newmexguy
Las Cruces New Mexico USA
Front door hinge set. From '64 four door sedan. With hardware. Drivers' lower needs rebush. Clean desert condition. Located in las Cruces NM 88005. $100 plus medium flat rate box shipping.
Those are front door hinges for 1962-65 A-body. Not priced as cores for sure.
Needs more than a larger pin. Very hard to drill the lower/outer hinge as it is hardened steel and requires a carbide drill bit and reamer.
The springs and rollers will need replacing as well as the ramps on the hinges ground down and polished smooth.
Lived in Albuquerque and just south of Chama. Elk country.
