1963-65 Plymouth Valiant or Barracuda:
New Die Stamped Quarter panel patch panels. Correct gauge thickness - Made in the USA - not Taiwan Junk. We have two versions available. The first is the wheel well patch - covers the entire wheel lip area with 3" additional sheetmetal all the way around - square cut. The second is the patch behind the wheel well lip (covers the first 6" of the wheel lip itself as well) to the rear valance panel. Goes up to just past the body curve in the panel that is a little above the rear bumper level. Note: the wheel arch lip where the wheel trim screws will go through to hold the wheel trim mldg on may have some slight waves in it towards the very bottom back edge – about 3” aprox. of the wheel lip underside…this from punching of the panels in the die may cause some imperfections from panel to panel at this location. It is an easy fix or won’t be visible once wheel trim is put on…we are talking very nit picky issue here but we do want to point this out.
40" long by 19-1/2" tall. Dead center of arch to top of panel is 7" in heigth.
KK-635WPL 1963-65 Left Wheel Well Patch Panel $174
KK-635WPR 1963-65 Right Wheel Well Patch Panel $174
30" long by 14" tall
KK-635RPL 1963-65 Left Rear patch panel $155
KK-635RPR 1963-65 Right Rear patch panel $155
