[FOR SALE] '64 Barracuda Back Seat
is there rear black seat belts under the seat ? you have to pull those 2 bolts between the seats , there should also be a build sheet in there i need the seat belts if there in there
pm me dirrect thru fabo if it has them
It can go two packages via USPS, but it's going to be extremely expensive to California, probably $75 a package.
ON something large and relatively heavy like seats, I've used FedEx - beats the USPS by a large margin.
Large stuff ships best on Greyhound freight. cheap. They just put it on a bus going to where you need it. You should check it out.
