Rebuild the poly!!Wagon has been sitting too long, 318 poly is stuck. Is the 318 worth the effort to free, or a total rebuild? Anyone in the upstate NY area have a running big block for sale?
whatever you decide, which ever way you go, that car is definitely a keeper! very cool. I kind of like the 318 poly, but a 383 might be the cheaper move in the long run.Wagon has been sitting too long, 318 poly is stuck. Is the 318 worth the effort to free, or a total rebuild? Anyone in the upstate NY area have a running big block for sale?
So, I bought PB Blaster and some Marvel Mystery Oil. My understanding is people pull the plugs and put one or the other in there to soak for a time, then turn engine manually. Anyone have any experience with this?
I use ATF, a dab in each cylinder for a couple days.I think I'll try a little PB Blaster first, and if that doesn't work I'll hit it with the MM and let it soak for a week. It's a little strange, there is no evidence of water damage anywhere, no water in the oil, plugs were clean, carb looks fine, parked years ago and it's locked up
