The guy working on it is saying that it's gonna need 6 to 8 washers per bolt to bridge the gap in the 2nd pic. Or machining adapters for them.
That is a reason I am using the original Kelsey Hayes they are made to fit. It appears mixing and matching has put your centerline for your wheel out at least 2 inches from stock. Now you are wrestling to try and bring that wheel back in those 2 inches.
I'm scratchin my head as well as to why there would be a difference in the two matching up. I have no idea.
Why did you pull the drop spindles?! They are not the problem.
The tire clearance problem was from trying to run to tall of a tire. These early As do not have the same giant wheel wells of the later As. You simply cannot run an early A, with stock fenders, that low with 25"+ tall tires.
Put the drop spindles and all back on, and go buy a pair of 24"-24.5" tires and your rolling.
You're way overcomplicating this problem.
Yeah but, my point is why is there a gap at all? That caliper bracket bolts to the machined face of the spindle right? So, how is that different from the drop spindle to the stock disk spindles? The only way that changed from the drop spindle to the stock spindle is if the drop spindle has the bearings riding further out from the body of the spindle, which would mean a different track width. The drop spindles are based on the stock spindles, so, that dimension shouldn't be any different. And, at least on the drop spindles I ran on my Challenger, it wasn't, because I swapped from drop spindles to stock FMJ spindles on that car without a change in tire clearance. And I would have noticed, because there's no extra tire clearance on that car.
The difference he's dealing with is no where near 2" per side. If it were his tires wouldn't even still be inside the fenders. The difference between the KH's and the stock 73+ disks is listed by the factory as .7" per side. Wilwood claims the offset change on this disk kit is 0".
Car is at a shop. My buddy's. I don't have room at my house to do the work.It's hard to tell from pictures without measuring the diameter of the spindle, but those do look like 73+ spindles. Which means there shouldn't be any difference in how those caliper brackets mount. I think that gap is an install problem not a parts problem. Is your car at a shop?
Well, that's not entirety true. If the car wasn't sitting that low it wouldn't be as much of an issue. I agree the tire height probably needs to change, but the track width appears to be too wide as well. There isn't a difference between the drop spindles and the 73+ disk spindles for track width, that shouldn't change between those two so that would still need to be addressed. But unless you're slamming the car on the ground you don't need the drop spindles. Increasing the torsion bar diameter allows you to drop the car with the adjusters and the geometry is better.
72bluNblu you say he is only dealing with .7 difference I say it is more by looking at what he has in the pics but I am not here to argue. He has stated he had drum spindles with a hub he bought to adapt it to disc with the hub spindles. I could care less I was just trying to figure out the abortion he has with the mixed up parts. carry on but my bet where that wheel sits it is more than .7 out.
Haven't had a chance to get out to look at the car yet but got these sent to me yesterday.
