swing69
fightin' socialism
For my HS project car in central NJ:
The RR qtr (back corner) took a hit many years ago - the tail panel and RR qtr. are kinked. We don't have a way to pull them... We are leaving the "patina" so rough body work is good enough.
I'd like to replace the tail panel and trunk lip from just right of the lock to the tail light. Anyone have a 65 they can cut this piece from? also....maybe all around the right tail light housing section. we can cut a piece it to fit Its SO kinked, no hope of really straightening it.
how would you repair rust through above the pass. door striker? anyone have a section to fit this cut from a car?
Picts are in my post in the early A bodies forum. I can send a pict with more precise cutting info....
thanks....what do you have????????
