65 Barracuda Spear clip
Keith Mopar
Mopar Nut
Calgary AB.
Does anyone know where to get some 64 or 65 barracuda spear clips? I need the end clip which has a speed nut on it and 4 of the clip in ones. Or anything that can work in the original clips place.
I’ve looked at reproduction clips but doesn’t look like anyone remakes them.
Fender molding clips? Can you slide them out for a backside picture
Keith - would the clips from a 65 Valiant convertible be the same?
Or maybe these type clips? They’re the same width as the molding but a little too thick to slip into the Valiant molding
Here is a pic of the ones I have, the one clip looks like the ones in post 4. The very first one bolts in and the other 8 are the clip in type. The clips where they slide into the spear are 13/16's wide
I got both the spears on thanks to 65 Dartman.
Those clips both worked great and matched my original clips perfectly.
I got mine from Laysons and they were pretty snug but they did work with the help of dishwashing liquid and some persuasion. I also got the threaded end one from them.
The originals were snug fit as well. I used a tiny bit of oil on them and then they slid in fairly nice.
