In stock and ready to ship......
Trunk Lid Prop Strut Kits
Is the prop rod in your car so rusty it won't move or is it missing? Are you tired of the trunk lid falling on your head or using a mop handle to hold the lid up? If so, here is the solution to your problems. This is a new replacement trunk lid prop rod kit for the 1964-66 Barracuda which had the spring loaded rod. This kit is NOT intended for the early 1964 Barracuda that had a different slider mechanism found on the passenger side of the vehicle versus the drivers side. For those cars or for any Barracuda's that do not have the "S" holes already in the trunk lid can retro fit our "B" type trunk lid prop kit (See Below).
The strut selected for this application is properly sized to provide the correct lift force, lift height and compressed length. A dampened strut is used in this application to provide for reduced stress on the 37+ year old trunk lid hinges. The trunk lid must be raised by hand, with the dampened strut, but will stay open in any position.
Type A:
This kit does not require drilling any holes in the trunk lid brace or inner quarter panel bracing. The kit includes a new and unused, dampened, gas filled strut, special galvanized mounting studs, mounting hardware and detailed mounting instructions..
The special mounting studs are sized to properly fit in the existing holes (where the original prop rod "S" hooks fitted) and are bent to the proper angle for this application. This kit includes flat washers and fiber lock nuts for attaching the mounting studs. The detailed instructions describe installing the mounting studs and gas piston.
TA-TLPA 1964-66 Barracuda Type A Trunk Lid Prop Strut Kit $ 164.00
Type B:
This kit does require drilling holes in the trunk lid brace and inner quarter panel bracing. The kit includes a new and unused, dampened, gas filled strut, special galvanized mounting studs, mounting hardware, detailed mounting instructions and templates for properly locating the four mounting holes.
This kit includes stainless steel machine screws, flat washers and fiber lock nuts for attaching the mounting studs. The detailed instructions describe installing the mounting studs and gas piston.
TA-TLPB 1964-66 Barracuda Type B - Trunk Lid Prop Strut Kit $ 154.00
