FURY440
I'm looking for the body molding/trim clips. I did some searching, but came up with nothing so far.
You will probably not find those fasteners unless they were used for more than just the 66 side trim!! Unfortunately, nobody likes to support the one year only parts, and these are even rarer because only Signets had that trim, and only in 66!! Might have to use a butterfly style clip and buy it from the back, unless you can find a butterfly clip that size with the push in button
Anyone have any ideas for these molding fasteners?
I'm looking for the same molding clips for my 66 dart wagon 270 . No luck yet either. Tomorrow or Monday if I get out of work on time I'm going to check out the auto body supply by my job. But I'd rather have the original new if you or me could find them.I'm lookin
Most every hole is accessible from behind the panel, so I'm going to use the butterfly clips that nut on from behind! Of course my interior is out for a floorpan change so I can just zip em in at this point!
Thanks. Can you let me know what you use when you get to that point please. Where did you find the floor pans. Mine are in great shape for exception of a small hole in the front that can be fixed with a weld in patch.
