67 Barracuda Wheels and Tyres
E74
Active Member
Sydney
Just bought a 67 Barracuda ,car is in Seattle WA at the moment shortly to be transported to Longbeacxh CA for shipping to Australia.
I am going to buy some Cragar keystone klassics for it before it leaves and I would like to get as much rubber under it as I can but I have no way of checking what will fit from the other side of the world.
so from your experience's should I buy:
15" x 8" and 15" x 10" with 275/15 and 275/15 Tires
or is this too big for it and I should just stick to;
15" x 7" and 15" x 8" with 215/15 and 245/15 Tires
I don't want to go through all that tire rub/scraping billshit and am happy to fit the narrower ones if you think the bigger set may be a pain in my ***.
:newb:
15x8 rims 41/2 inch back spacing.
275/60/15 tires.
I can tell you the 1st version is to big and will have issues if it fits at all, unless it is tubbed?
I run 255/60/15 on rear with 7" 4.5in backspace and have a good full well without lateral rubbing, maybe an inch clear either side. Front 215/70/15 on a 6" rim with 4" back space. I have good clearance with front fender when turning.
The tires used firestone firehawk indy 500.
