67 dart bushings and ball joints
dodgedifferent2
southwestern, Ontario
I have a 1967 dodge dart that i plan to put in the spool mount k frame
I am using the lower control arms with the wide sway bar mounting point.
Power steering
I changed the upper control arms to use the 73+ spindles and viper calipers.
Now i want to replace all the rubbers, ball joints, tie rods and bump stops
Is there a kit with all this kind of change? or do i have to slowly piece the puzzle together piece by piece?
Was planning on going the MOOG route with the problem solvers.
pst, or if you have a advance auto up there you can get everything thru them, thats what I did on my scamp.
