67 wiring
matthon
Looking for a complete uncut under hood wiring for the engine temp, coil, starter relay, etc, from the bulkhead.
Could also use uncut wiper motor wiring.
Which engine? A/C? I assume this is for a '67 Barracuda? 2 speed or variable speed wipers?
Thanks, Mark
383, no a/c, 2 speed wipers, 67 Barracuda.
My assumption is if wiring includes a/c wires I can just pull them out, but what is the difference between BB, SB, and 6 wiring? And wouldn't the Dart wiring be a match as well?
The main difference in the engine wiring is length of some of the wires. Mainly the coil + and oil pressure sender. I know I don't have a genuine 383 harness but I may have one for either S.B. or /6. You have to lengthen the S.B. coil wire to use on a B.B. or tape back the oil pressure wire on a /6 so it comes out back by the firewall. No biggie on either one unless it needs to be 100% stock. I'll check tomorrow and see what I can find.
Thanks, Mark
