[FOR SALE] 68 340 short block new apart
moparraceman
mansfield ohio
i have a std bore block 8-10-68 [Lm23P9B171273] STD STEEL CRANK with stock balancer,new 10.5 to 11.0 pistons depending on head cc . new rings , new rod and main bearing,new freeze plugs and cam bearings.rods cleaned checked new arp bolts . new blue head gasket . used very little hp comp timing chain set ,front timing cover,water pump,fuel pump ,no oil pan or pump everything either new or cleaned and painted $1850 pick up mansfield ohio thanks for ad
What camshaft installed? Crankshaft have pilot bearing for 4 speed? Do you have original factory camshaft? Thank you.
Can you ship to Florida? Would have to be crated and strapped to pallet and also weighed.
Thanks.
