derrangedgadgeteer
One thing about my dart which I don't terribly like, is the front end. I'm sorry, but all of detroit got hit with the business end of the ugly stick in the 70's. I have recently found a local junkyard though, with a whole bunch of older darts and valiants, any number of which have serviceable front clips.
I know the hood, fenders, bumper, grill and valence would have to be changed over all together. but my question is this: Would I have to switch out the inner fenders too? Radiator support? or will that swap even work at all without cutting out everything from the subframe forward and welding it under the car?
The ol calibrated eyeball indicates there's not much different from the firewall back. It does indicate, however, that the inner fenders look somewhat different, and I can't tell if the subframe is different or not. I just wonder if the older sheetmetal will bolt to the newer inner fenders and whatnot, and if not, if the older inner fenders will fit in place of the newer inner fenders. If both answers are no, then I'll live with my current front end and put push bars on it.
