[SOLD] 68 Cuda 318 valves, rockers, PS pump, 904, etc
yotah1
Dearborn
As I'm rebuilding the car, i'm trying to make some space in the garage and basement, I hope the prices will be fair.
It all comes from my 68 Cuda, all was running fine.
It is all located in Royal Oak, MI 48073
Shipping can be arranged but if possible I would prefer local pick up in the Detroit area.
Prices are negotiable in a reasonable manner :)
Happy buying guys, I hope these will help someone else on their car.
Contact here or via PM first, then i can give a call.
Automatic transmission lever : SOLD
Stock piston for a 318 engine, 4 valve recess, with pins and rings : 120$
Starter motor : SOLD
Automatic transmission pedal assembly (with pads) + parking brake assembly : 40$
Power steering pump (original) : 25$ (pending)
904-7.25 driveshaft 2.75"diameter 51.43"length (small U joints) : 50$
original 318 air filter : 20$
Stock height 1.50 ratio 318 rockers (16 pcs) : 50$
New 318 stock diameter valves (1.78" - 1.5") : 200$
Original valve covers (sandblasted and powder coated in matte black) : SOLD
Original radiator with auto trans for 318 engine (26"radiator I think it is... some bends and chip marks but no leaks) : SOLD
original 68 A-904 transmission with linkage (worked fine when i got it out, shifted great) : 200$
Fuel pump : 25$
Does the power steering pump include the mounting brackets and bolts? What is shipping to 91791. P.S. Your inbox is full.
Everything's included, and I cleaned my inbox.
Estimating shipping before lunch for everyone.
Radiator, shifter, valve covers, starter are sold.
PS pump is pending.
Idler pulley would be 15$ + shipping (approx 8$)
Pistons, driveshaft, fuel pump, valves, air filter, pedal assembly still for sale. The rest is gone.
Pistons, driveshaft, fuel pump, valves, air filter, pedal assembly and transmission still for sale.
Pistons : 100$
Driveshaft : 40$
Fuel pump : 15$
Valves : 150$
Air filter : 15$
Pedal assembly : 40$
Transmission : 150$
Lifters : 40$
