The console has a cigarette lighter, and the light for the PRNDL. That's just about it.
It all seems so simple now... I was thinking the switch on the shifter was for the neutral switch.
I dont have a 68 service manual but I do have a 69. However there are a few changes between the years.
Still looking for a lower shift rod for a 904 console car. May have to fabricate one. One member has one but wants $100 for it and the levers I don't need. Just can't get myself to pay as much as I pick up whole tranys for...
Thanks for your help.
There is no difference in the linkages from a 727 or 904. I've interchanged them both and used the same linkages.
Thanks Rocky..that makes sense. I am running the later model neutral safety wiring not the switch on the shifter. I assume that is the other circuit you are referring to.
The 68 and prior wiring diagrams are so vague....
