[SOLD] 68 up idler arm mount
ssba
rensselaer in
I am home brewing a k-frame starting with a 67 K that I already have.
I wish to cut off the welded on 67 idler arm bracket and weld on the newer 68 up design.
The picture shows the 67 style that I plan to cut off If this add can help land the part.
Eddie, I hope not to have an entire K-frame shipped if possible.
Rather ship a smaller torched loose piece I can clean up.
Shipping a K-member is cheaper than you might think. About $50 FedEx...They weigh about 35 lbs.
Every so often I've seen a bracket for sale on the site here.
Thought I'd see if one turns up.
Figured I could make this 67 part work for a 440.
Its not pitted with rust or have any LCA pivot welds problems so I hated to toss it out.
Got the engine stands cut off of it and gonna remove the idler bracket next.
Hope someone's got a part before I go to the trouble of making one.
Is the 67 idler mount damaged? The 67 idler mount is not that bad. Are you sure you need it? Just get a 67 383 pitman arm and use any pan you want.
I have a 68 /6 K member coming out today. I will check the condition of the bracket and let you know.
Yes 73 is good. 68-76 bracket will work.
The 67 bracket has been removed.
Thanks for any help. Let me know what you got.
