Was able to see it in person. Well one side and the cabin that is. The hood latch is not functional so couldn't get into the engine bay and the trunk was closed and had no key at hand.
-Looks like was last tabbed in 1988 and may have been in same spot since. Passenger fender damaged in collision. Looks to be all original. Definitely a 69 model.
-Body will need lots of love... rust thru in quarter panels and trunk, likely other areas. Glass is good except windshield has a hole. Grill damage (from wreck? idk)
-Interior rough from moisture and the upholstery is needing covers and foam at least but I would guess the frames may be salvageable. Headrests appear to be decent other than some rust on the rods. Has a "wood" steering wheel that is rusted and cracked in one spot on the plastic "wood" wheel portion. Dash is ok and gauges are there with an aftermarket radio installed (dash cut to fit).
No A/C vents in cab so assume non A/C car.
Did not check floors for soundness. Car sunk into soil so unable to see underneath. Carpet is all there.
-Appears to have original wheels and standard wheel covers. All tires flat and old.
-Exterior lights all there. Front signals appear to be ok and lenses have cracks. Taillights have good plastic with no apparent cracks and frames have some pitting.
Hope this info is useful to someone.
