69 cuda parking lite problem lense
22dog22
northampton ,pa
Ok i bought new parking light lenses for my 69 cuda, at first look them seemed correct, but went to install them and they look like they made them to big , they are wider and higher and the chrome center cap is larger, almost like for a B body car, i took photos with measurement of my one's on the car, could they be from another model car , because when i look at another place to order them from they look like the incorrect ones i have , when i look at Herb .com part number 309l is what i get when i order that
part # and they do not match up to the ones on my car so i am thinking my are from another model car ??
What you have pictured is a 67’ barracuda grill the ones for the 69 look similar but are bigger and obviously don’t fit. So you need ones for a 67’ instead of a 69’
Here’s a 69’ grill for comparison
I snagged this from the site so hope whoever it belongs to don’t mind
Heres pics of my 69 signal #2930490. Gotta zoom in to see stamped part number. I believe it's for pass side.
Notice the chrome button is more rectangular.
THANK YOU !!! Cudascott i will order the 67 year and i did not know that my grille surround was a 67 !! thanks again !
you are correct 4spdragtop, the picture you show is what i got when i ordered the 69 style so mine must be the 67 style like Cudascott states.
Yes your grills are 67’ The header panel looks to be 68’ and your hood will be 67’ or 68’
Look like you have a 67 header panel and hood also with 69 fenders
67’ header panel has P L Y M O U T H across it don’t see that I’m still saying 68’ on the header panel. Then again I don’t see the outer screw on the headlight bezel
but that don’t mean much.
22dog let’s see a pic of the whole header panel.
And were not nit picking the differences, it's so you dont run into the same problem as this in the future.
I personally like the 67/8 hoods better. 69 they dropped the ball.
A '67 nose, grille, and hood worked for my '69 before I found '69 stuff......
