69 Cuda rear floor
Woodys_Cuda
Ontario, Canada
Ontario, Canada
Does anybody know if there's a difference between the back floor section that extends over the wheelwells on a notchback and fastback? Is it the same piece on all Abodys? Thanks!
And yes I know it's probably a dumb question.
More like welded in between the rear inner wells rather than over them. Wouldn't be the same on "all" a-bodies since the wheel base length differs. As for fast and notch, I don't think those are different unless rear seat mounting plays into it.. BarracudaKid would know for sure.
Thanks for the reply Redfish! I'm just trying to find out what I might need there as a floor pan to order it. This pan was neglected by the PO and I want to get the right one.I know the notch has supports welded in behind the seat and you're right about wheelbases too.
The up and over panel is the same basic piece on the A's regardless of wheelbase. Part number 2842080, is the same for notch, fastback, darts and valiants.
The wheelbase difference is dealt with in the main floorpan section.
