'69 Dodge Dart GTS
Finally felt like messing with it some, got the engine ready to pull one day this week. Then I can start on body work in the engine bay.
Got the engine out today and power washed the bay/engine off. Basically back to square one with it.
Nice seeing you working again Kegan! not that you had stopped...I mean logging stuff here in abodys :thumbsup: :)
Yeah, I'm mostly on the neon forums these days. Decided it was time to make a little progress on this thing.
Where I ended the day off at, rust isn't bad at all for a car that has sat more than ran since the mid '90s.
Got the bay stripped a little more today, going to go look at a couple parts cars tomorrow hopefully.
Got the top end tore off the 340 tonight, doesn't look much different inside than it did when I put it together over a decade ago.
Hit up the Indy swap meet and got some nice hood hinges, engine paint from Mancini and new in box set of Johnson solid lifters.
I messed with it a little today, still waiting on the retainers for the hood hinges to show up. Dug through my hoard and found the latch support and all the needed hardware for install.
Got it loaded up to take over to a buddy's shop so I can do the engine bay body work and paint. I'll do the rest of it later on after the car is going.
Got the cover plates off the firewall and started sanding, the F8 under them was still nice and shiny haha. Probably been on it since the '70s.
Stopping point for the day, everything is ready to be ground down tomorrow.
