Hello, could someone help me to figure out a strange problem on a '70 Dart Swinger....
Brake lights work normally, both of them light up with no turn signals when I brake.
But, when I turn on the LEFT turn signal, (AND I apply the brakes), the right brake light goes off. If I BRAKE first, then of course both brake lights come on as normal, but as soon as I hit the left turn signal, the RIGHT goes off.
This happens with or without tail lights turned on, I wanted to see if that had anything to do with it, but no, same.
This doesn't happen with the right turn signal, that one works as normal (i.e, left brake light is on (WHEN I'M BRAKING OF COURSE) while right is blinking).
Could it be the turn signal switch inside the column? The flasher? The hazard flasher?
The brake light switch?
I replaced both rear bulbs to make sure as a first step.
thanks
thanks
