Hi guys,
I have a 1971 Dart that I replaced the ignition switch on. Before replacing the switch I had no issues. After installing the new switch, when attempting to start up, I noticed the fusible link at the bulkhead began to smoke. Checked under dash and the ignition switch connector from the column was also hot. Any chance it may be crossed wire connections or bad connections in the connector? The bottom portion of the connector is the new switch harness. Any help is greatly appreciated.
