65Vart
anybody already running a 15 x 7 with a 255/60/15 on a 70/71 dart with NO mods?. Its time to by new wheels and tires . Need to see proof they will fit. There is mixed messages out there.
DartVader, what's your back spacing and do you have pics.
My rear sits a bit higher for whatever reason too. But every car is different, the best thing you can do is test fit a set because what fits on my car may not fit on yours. If you were closer Id let you test fit mine.
I am changing out my rear end to a shortened 8 3/4 pretty soon, so I will be able to fit a bit wider tires as well.
I ran 275 60s on the back of my 71 on 8" wheels. I don't remember the offset. That was around 20 years ago. They never scrubbed.
If that's not proof enough, oh well.
That's even higher than with S/S springs. No where near stock height, which is what the OP is asking about. I have S/S springs & stock shackles on my '69 and it sits lower than your car. I can't get a 235/60-15 tire on mine no matter what wheel or offset I try. They either rub on the inner or outer fender upon cornering. I think this proves that every car is different, and what may work on one won't always work on another.
You can't compare a 69 to a 70. The wheelhouses are different.
