70sublime340
All the pieces to convert your column to Floorshift. Tube, and all collar pieces with hardware. No ignition switch or tumbler. In process of cleaning and painting factory black. New release lever decal also will be installed. Picture is of complete column prior to disassembly. Not included is the actual column shaft. With these parts you can use them on any column power or manual. No stripped holes or broken pieces. $125obo from 93901.
Painting it factory black, but if you would like another color I can leave it in primer ready to paint
