72 340 disassemble
darndart
Surrey, ND
Finally started to disassemble the original 340 from my 72 Demon. I got the car back in 1985, I’m sure the engine has never been apart. Block is a early 71 casting date. Even stranger, the bearings are dated 11-69. It’s a forged crank engine, came with 915 J casting heads with 1.88 intake valves. Is it normal to have these dated bearings?
Chrysler used up what they had even when model years changed. Later in the '72 model year they went to a cast crank. I had an early production '72 Challenger 340 and recall some oddities. But it was too long ago and I don't recall the details.
Can you post a pic of a piston at TDC?
Obviously normal for that engine and car since the serial number says it's for a 72 model.
did Chrysler use clevite bearings from the factory? /maybe someone re-ringed the engine /what head gaskets came off / should be a mopar part# on bearing? they did start making that bearing in 1964 maybe older/ early 318 L
Got all the pistons & crank out today. Dates seem to very on the bearings. Ran a quick ball hone on the cylinders to see how bad the rust was. It all came off very easily.
I'm curious is this a four-speed car or automatic?I have read that the existing Forged steel crankshafts were put into four speed cars as they use them up at the end of The run before going to cast cranks.
yes, it is a 4-speed car.
My original 340 Duster was a 3 speed manual '72. It came with a cast crank. Could the forged cranks have been restricted to 4-speed only and not all manual trans?
I don't think there's a definite answer to the question of where the last forged cranks went in production. I have read that they were used in four-speed cars till the supply was gone and cast cranks where the order of the day. What month of production was your 72 duster? It seems more reasonable that the Forged cranks had been used up and all cars were getting cast cranks by the time your car was assembled.
I don't recall. That car was totaled almost 50 years ago. IIRC I'm thinking it was a late '72 model.
They probably used whatever cranks were in the bin that day...
Right. Plus, that car was a Mr. Norm's and had 12.5:1 TRW's in it when I got it. No telling if they changed out the crank at that point, but not likely, as they would have had to swap damper, timing cover and radiator at the same time.
You are going to bore it right? That gouge is significant.
Yep, it’s at the machinist. He measured the bores and said it will go .030. Also having it decked & rebalance the new rotating assembly.
If you're going .030 over you might want to have it ultrasonic checked depending on cost.
