You can do an easy, rudimentary test to see if the cylinders are all firing. First, though, do some basics. Make sure the plug wires are in the right firing order. NO 5 and 7 are easy to switch Make sure the timing is OK. Take a quick look at all the plugs
If you can't find the problem, warm it up so it will idle, and get it set up to "best" idle. With engine shut down, remove all plug wires one at a time from the dist, and put them back in "loose". It helps if you have some insulated (non metallic) pliers like a cartridge fuse puller. You can get these at any electrical supplier, or Lowes/ HD. Pull one wire part way out of the dist, with the engine idling, and as you bring it "out" slide a grounding probe into the dist. Use a tach and monitor RPM or LISTEN carefully. Each position, when shorted, should drop RPM equally. If you get a "dead" one you can tell immediately
If you don't have insulated pliers, you can also loosen the dist boots and insert small brads/ pieces of wire/ paper clips down beside each plug wire. Now, start it up and use your grounding probe to simply ground each one in turn.
