72 Demon headliner
Terry Dingwell
Active Member
Alberta
Question: When installing a new headliner in a 72 Dodge Dart Demon, do the two rear sail panels go on before the headliner or after? Thanks
Yep, they go last. Start in the back with your 2 wire hooks clipped to the rear most bow and pull toward the front. A steamer helps! Good luck.
The headliner I'm installing is the ABS plastic type covered with fabric however that shouldn't make a difference as to the install sequence should it?
