I IRISH RT Well-Known Member Joined Nov 1, 2010 Messages 254 Reaction score 5 Location Wellington Feb 3, 2017 #1 Picked up a Shorty 727 SB yesterday was told they had stronger internals and different gear ratios than a standard long shaft . any truth in that ?????
brian6pac Legandary Member Legendary Member Joined Nov 15, 2016 Messages 5,668 Reaction score 4,093 Location N.E.Ohio Feb 3, 2017 #2 The short shaft should have 4 pinion planetary gears, not sure on gear ratios.
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,311 Reaction score 8,489 Location Kindersley, Saskatchewan, Feb 3, 2017 #3 They are basically the same internal wise and gear ratios are all the same. 2.45. 1.45. 1.0 bb shorty Trannys from trucks and vans could have 4 pinion planetaries. There is no rhyme or reason to chryslers whimiscal ways. Kim
