flathead31coupe
With the disc's and steels in the drums..is there a feeler gauge check to see if the need replaced.. Or another way to tell..they look good and not burnt..
Be strict on this measurement, as too little clearance can cause creep in N with a stock converter.
check your clearance with the disc dry....then soak them and assemble them..
oh...see you want to see if they are warn out...disassemble and inspect them for wear and look at the steel for heat marks on them
hard to check clearance with the atf in there.
