moparspares Well-Known Member Joined Aug 10, 2010 Messages 616 Reaction score 103 Location Scarborough, Qld Nov 9, 2018 #1 I pushed parking lever rod and it went in far to easy. Is there any way this can be installed incorrectly?. All bolt holes line up in VB. I get worried when its that easy
C CudaFactHackJob Well-Known Member Joined Mar 17, 2016 Messages 2,623 Reaction score 1,154 Location Hemet, Ca. Nov 9, 2018 #2 If you're using a 904 rod then it's too short and you won't have park. If park locks the output shaft then it's good.
fishy68 Tyr Fryr's Inc. Joined Jan 11, 2005 Messages 16,584 Reaction score 1,264 Location Central, IL (Hooterville) Nov 10, 2018 #3 Sometimes the parking lever can be a PITA to get in and sometimes it drops right in. Maybe you got lucky. If it locks the driveshaft in park your ok
moparspares Well-Known Member Joined Aug 10, 2010 Messages 616 Reaction score 103 Location Scarborough, Qld Nov 19, 2018 #4 Thanks guys locks up in park. Usually crap like that fights me all the way but not this time. Was my lucky day
MrJLR Built, not bought FABO Gold Member Joined May 14, 2015 Messages 5,619 Reaction score 6,715 Location Menifee, California Nov 19, 2018 #5 It's actually easy to install if the notch lines up... I just turn the shaft a little until it slips right in....you just got lucky the first time. Jeff
