BIG-B-Barracuda
where is the oil port on a 727 to fill up? :coffee2::burnout:
And just so you know.....check the fill level with the transmission warm, and idling in NEUTRAL, while the car is sitting on level ground. DO NOT check it while the car is in Park!
define slow then?
the tube I am referring to is close to the firewall - having never done this with a big block I can only comment on where I know it to be on a small block - it's behind the motor on the passenger side - pokes out near the valve cover - you'll need a funnel to fill - ATF= automatic transmission fluid.
Roughly around a quart a minute, faster when warm and even faster when the funnel slips out of the tube.
