727 what size bolts for dust cover?
RockinRobin
Corsicana, Tx
Small block 727: what size are the bolts supposed to be that hold the dust cover on the front of the bell housing? Somehow I wound up with metric bolts, 6x1mm. That cannot be right.
I believe most of them are 3/8" - 16 and the smaller ones are 1/4" - 20 ... Maybe the largest ones 7/16" -14
Dust cover....pretty sure they are all 1/4-20, small block and big block alike, 5/8 or maybe 3/4 long max
7/16 x 5/8 with 14 threads per inch are the big bolts that hold the braces on. If u don’t use the braces u will have to make up the thickness with washers. Kim
7/16x5/8? Huh? Don't know anything that uses a7/16 thread bolt that short!
