73 big block dart
mopar65
Laquey MO
I have a 1973 dodge dart. was a factory 318/904 car that i put a 440/727 in. everything works on this car except the horn wipers.they were missing when i got the car.the body is in pretty good shape but has the normakl rust that a-body are known for. looks like the car has had the front floors patched. but the front and rear frames are solid.the paint is starting to chip here and there.the truck is pretty much rust free. ui cut the spaer tire well out to install a 12 gallon fuel cell.the car has sub frame conectors and has ahd the springs moved in 3 inches perside, the car has factory 73 disc brakes which i just put new rotors/ bearings and seals. the calipers and pads look new. i just installed new lower control arm bushings, struit rods and lower ball joints, the upper bushings and ball joints are like new. ok on to the engine. i bought the short block used but only had 1000 streetmiles on it. but here goes.i have all the paper work that shows what all machine work was done to the engine.
1973 0.030 over 440
steel crank
wisco pro true forged pistons
eagel rods
hv oil pump
moros 1/2 hemmi oil pick up and 8 quart pan
billet 9 keyway timing chain
like new crane 1.6 gold roller rockers
like new manton 0.125 push rods
huges billet steel rocker shaft hold downs.
mopar m1 tunnelram
2 carter comp 750 carbs
tti 2x3-1/2 headers like new only 10 passes on them
mopar aluminum water pump housing
cvr electric water pump
summit 27.5x19 aluminum rad
ok these parts are brand new with less than 20 minutes run time.
comp cams solid roller that is 264 at 0.050 and has 634 lift with the 1.6 roller rockers
brand new mopar black valove covers
brandnew crane HI-6R ingtion box
brand new firecore billet dist and wires
727 was set up for racing useing crt trans parts.
alto eage red clutches and steels
red solid front and rear bands
billt front and rear servo pistons
crt race RMVB with low band apply
mopar deep chrome trans pan
car will have calvert 90/10 shocks on the front
mopar 50/50 long shocks on the back
mopar 002/003 super stock springs
back braced 8-3/4
moser 30 spline full spool
richmond 4.10 gears which are noises. bugt will come with a brand new set.
moser 30 spline axles with 5/8 wheel studs.
has weld drag lights 15x3 in front 15x8 in back
has M/T sportsman runners in front
brand new no passes M/T 275/60/15 drag radiels
has B-body drum brakes also.
well i hope this is enough info and if there is something i left out please fill free to ask me. i had a lot of pictures of the car but they were on my old computer that crashed. so i only have a few pics on this computer.if there is something you would like to see let me know and i will try and take a pic for you. but please no tire kickers. you can pm me here or email me at [email protected]. I am asking $10,000 obo. but somebody please make me a offer i want this car gone. thanks Mopar65
