have owned since 07 and put 0 miles,,,69 340 1st bore 030,,scat stroker kit internal balance,,eddy closed chamber heads,,kevco oil pan,,milling HD oil pump,,mopar 528 lift cam,,proform 750 race carb,,summit mini stater,,crane adjust rockers which had metal removed so as not to hit keepers,,only old parts are headers and torker 2 intake,,,new AMD metal all around [pic's of car under cowest],,new vynil top door panels rug,,door gaskets,,trunk gaket,,new head liner still could use adjustment,,,,trans ATI reverse manual shift,,had shop rebuild and use older case,,3500 hughes stall b/m shifter,,0 miles,, 8 3/4 741 with 3/91 posi,, the rear i did not change or look it but posi works,,had drive shaft cut and balanced,,was b body [would replace],,new fuel cell,,old holley pump,,parts have to go with car and there are many,,67 440,, 78 360,,motors 69 340 parts,,and bunch more,,,, had springs moved in 3'',,old perches still there,,frame tied, rear rims were made as to get larger tire underneath ,, floors patchs were put over old,, 4'' bolt pattern,,as i said i owned since 07 have clear ny title,,but never put car in my name,, asking 10 grand as is or 12 grand and dent will be removed,,,car in orange co. ny 1254 car was not a 340 car,,,8,500 WITH OUT PARTS,,,WILL END AND EBAY AFTER THIS WEEKEND,,COWEST432 MANY PIC'S ON SITE
