[SOLD] 74 Dart Sport
RAMCTD2003
340dart
Grand Junction, Colorado
I am posting this again. The first time I posted it I was selling as a roller.
Now I am selling it turnkey.
Over $20k invested in this car in the past 4 months!
74 Dart Sport originally a /6 car. Now has 360/727/8.75.
Car is in really good shape. Small rust in rear quarter and that's it.
All parts are new with only 250 miles on them!
Engine:
95 Magnum Block bored .020, square decked and line honed and internally balanced.
Speed Pro Hyperutectic Pistons
New Stock Rods
Stock Crank that was polished. Using standard main bearings.
Custom Lunati roller cam spec'd out by Mike at MRL. Duration Adv. 278/282
Duration at .050 227/231. Lift 530/535 with 1.5 rockers. I am running 1.6 rockers so lift is around 565/570.
Mildly ported LA Edelbrock aluminum heads. 2.02/1.60 valves. Completely worked over by Mike at MRL Performance.
Milodon road race oil pan .
Schumacher replacement poly spool engine mounts.
MSD Ready to Run distributor and MSD plug wires.
Transmission:
727 built by Phoenix Transmission. Handles up to 450 hp.
Cheetah SCS shifter.
Turbo Action 3500 stall converter. Set up tighter for the street.
Deep cast aluminum transmission pan.
New cooler lines.
Cooling:
Champion MC 374 4-core Aluminum radiator
Flex-a-lite mechanical fan
FlowKooler High flow water pump
Exhaust:
TTI 1-5/8" Shorty Chrome headers.
Full TTI 2-1/2" exhaust.
Rear:
A-body 8.75 housing
Moser custom 30 spline axles with green bearings.
4.89 case with sure-grip and 3.91 gears.
Right stuff Detailing rear disc brakes w/ emergency brake.
Suspension:
Hotchkis TVS system w/ Fox 1.5 shocks at all 4 corners
Hotchkis subframe connectors.
PST 1.03 torsion bars.
Wheels and Tires:
Front 17x7 Cragar Eliminator 500 w/ 225/50/17 Nitto 450 tires
Rear 17x8 Cragar Eliminator 500 w/ 255/50/17 Nitto 450 tires
Fuel system:
Custom built Aluminum gas tank by Hot Rod City Garage w/ Walbro electric fuel pump in tank. Works with stock sending unit.
All fuel lines are Russell Twist-loc with AN fittings.
Holley Billet fuel filter.
Aeromotive 3-65 psi fuel pressure regulator w/ return line. Can change out spring so you can run EFI in the future.
Please see photos below. Asking $14,000 or best reasonable offer. Car runs and drives amazing. Located in Grand Junction, Colorado. Clean title in my name.
Thanks for looking.
Here are some photos.
More photos
I know how much you guys like performance numbers so here you go.
I ran this at our local track for 4 races and won 2 of the events and won a Wally at one of them for the National Dragster Challenge on June 27th.
The best time has been 13.61 @ 102.45 in the quarter mile @ 7200' density altitude.
It's got a lot more in it since it is not really set up for drag racing.
With more rear gear and a looser converter I'm sure it would be in the high 12's here at my elevation.
