360Duster75
So im trying to find where my issue is on my 74 Duster with not starting. I can jump the car and it starts fine and run fine when disconnected but then it will not start on its own again after about 10mins. The battery is new, voltage regulator is new. It also keeps blowing the number 7 Fuse for domelight and all. I looked at the Alternator incase its not charging and saw the wires look different to me of the wires is solo and the other is 2 wires in one. Which way is the correct way to hook this thing up?
The solo wire is Green and the double wire is blue and green wires. I followed them to the voltage regulator and the 2 double wires are hooking on the to point on top of the connector and the gree wire is on the bottom right.
I am trying to upload pictures but they are not working.
