highflyer
tryed to start had noo signal to the relay..finally traced it to the connector that plugs into the seat belt module...module is gone...had to jumper the yellow wires in the red connector like a post on here says.....having trouble with the back up lite switch one place for the clutch and the b/l switch wants to go there also..my harness is 74 automatic trans with 3 wires and duster is 73..two wires man ual with wire to ground stud on the relay..how do i wire for clutch and bup/lite switch..please help..tx..j
